Internet speed not matching the contract
komarkzy
Digitalisierer
Digitalisierer
I've upgraded from 400mbit/s to 1000mbit/s a few days ago but the speed has not been updated.
I'm constantly getting around  350mbit/s - I've tried testing at various times of the day (mornings, mid-day, super late at night) and I'm constantly getting the same resoults. That said DL around 350mbit/s and Upload on expected level of 50mbit/s.
I'm connected to the router via cable ofc. with a 1GB/s connection.
It looks like an issue with the signal quality as I've been having the same issues while I was still on 400mbit/s.
Can someone take a look at this please?
Thanks!
12 Antworten 12
Hello komarkzy,
what speed do you get in your home network? Did you test with different devices? Did you test on weekdays in the morning as well or rather on weekends?
Kind regards
My home network works fine. I'm getting 1GBE speeds over cable.
Below some screenshots of file copying speeds in my network.
Moni_GK
Hello komarkzy,
ok the connection in the home network looks good. So I would like to take a look at the line. Please send me a PM with your customer data (name, address, customer number and date of birth).
Then please contact me again here when you have sent me the data.
Kind regards
Moni
I've just sent the data over Private Message.
Thank you!
Moni_GK
Hello komarkzy,
do you never get more than the 350Mbit? Please test the speed with the Microsoft Edge and our speed test.
Best regards
Moni^mmk
I've poseted this already in my initial post, but here it is again. Screen below.
Can you pelase just schedule a techician visit to inspect what's going on?
ERFD
Hello komarkzy,
the signal values at your modem are perfectly ok. No technician can change anything here. Is the device you are testing able to implement this speed? We can gladly instruct the technician. He will come with a Gigabit capable device and measure at the connection. If his values are significantly better, the deployment costs 99.50 euros.
Best regards Fred
It's a newly upgraded connection and the modem is exactly the same one that you've sent me (the one that's advertised with the 1Gbe internet) so I assume it's the right one.
If it's not the quality of the signal then it must be something else. I clearly capped somewhere around 350mbp/s.
I've seen other threads on this forum where people have similar issues and often a removal of some devices in the networking racks is discussed. This is a technical issue that I'm unable to solve myself. Please assist and schedule a technician to take a look at it. I've ignored it in the past as the difference between 400mbit and 350mbit that I was getting wasn't that big, but now that I've upgraded is basically a third of the speed I should be getting. I won't let this one go.
ERFD
Hello komarkzy,
have you ever tried connecting to IPerf or downloading one large and multiple files? Is it so identical or are there such differences?
Best regards Fred
