Access my network from remote
Sandro871
Hi all,
I am having issue setting up my newtork to use Xbox Remote play from a location outside of my LAN. I have set up the No-ip DUC on a raspberry pi, just to then figure my connection is ipv6 and I cannot access my Xbox from outside.
How can I solve this? I tried to look for many solution online, but nothing that could help.
Is anyone aware if Vodafone can revert me to ipv4?
Thank you!
ERFD
Hello, Sandro871,
DS-Lite is part of the contract. We do not change this any more. You can set your modem to bridge mode and it will automatically receive an IPv4. In bridge mode the router function of the modem is inactive. You can then connect your own router.
You activate the bridge mode in the customer portal.
Best regards Fred
