30.07.2019 20:17 - bearbeitet 30.07.2019 20:20
Hallo zusammen
I needed to pay my Mobile bill and transfered the money to this account DE04300700100270704000 that was connected to the SEPA charge..
From a little research I understand that this is not the correct IBAN for these kind of tranfsers or am I wrong? And if it's wrong what can I do
03.08.2019 10:51 - bearbeitet 03.08.2019 10:52
Hi MargKoukou,
welcome to the Community ![]()
You're right in that we use this IBAN for debiting your invoice.
However, it should be no problem if you accidentally transferred the amount yourself to this very same IBAN account.
You can send me a private message and I will check if your balance is even.
Best regards
Micha
Hi MargKoukou,
Best regards
Micha
am 19.08.2019 13:29
All settled via private message.
am 19.08.2019 15:48
Hi margkoukouu or margkoukou ![]()
Thanks for your feedback. ![]()
As I know that your first user name is no longer accessible to you, I take this message as authentic and close this thread.
Regards
Micha
