Router not connecting
eug-val
I have problems with my router. Ever since I switched it off, the router simply does not connect. All the symbols flash, try to connect, turns off and starts again. It has been doing this for the last week. We've ordered a new box from Vodafone but the same problem is happening again
I need help!
Jens-K
Hi eug-val,
without any info regarding your connection or modem model it's hard for your community to hep you here.
You opened a thread in our LTE board, so you are using a LTE router?
Regards,
Jens
