wifi 5 GHz problem with MacBook Air
medicol
App-Professor
App-Professor
I have  Compal CH7466CE cable modem
Internet 200 Mbit/s
wifi 2.4 GHz and 5 GHz both running
with 2.4 GHz all run good
with 5 GHz MacBook Air see the network, but has a speed of 3 Mbit/s (channel 120)
inspecting what is attached at the network with the cable modem, MacBook Air does not result in
Using a PC no problem
Anybody noting a similar behaviour?
Forcing channel 40 speed become top but still MacBook Air is not depicted as attached by cable modem
14 Antworten 14
Hello medicol,
did you do a factory reset already? Can you check the 5GHz WiFi with your PC? What speed do you get there? How far away are your devices from the router?
Kind regards,
if I get connected with my PC to 5 GHz I get normally 200 Mbit/s as per contract
with MacBook sometimes with 5 GHz less than 1 Mbit/s
In both case I am in front of modem at 3 meter distance
No, I did not try any factory reset, also because then I loose all my setting concerning the network
Anyway I can do it if you ask me to do it, let me know please
testing a new modem received from assistance
Martin59
Hello medicol,
feel free to keep us up to date.
Many greetings, Martin
@Martin59 I received a newest modem, Technicolor, it has also the steering option to be set up. I truly appreciate it.
Till now it seems better and MacBook Air is connecting good at 5 GHz, BTW I steered it at 5 GHz to extensivly test.
I keep reporting for sure
Have a nice weekend
