am 06.12.2020 19:30
I have Compal CH7466CE cable modem
Internet 200 Mbit/s
wifi 2.4 GHz and 5 GHz both running
with 2.4 GHz all run good
with 5 GHz MacBook Air see the network, but has a speed of 3 Mbit/s (channel 120)
inspecting what is attached at the network with the cable modem, MacBook Air does not result in
Using a PC no problem
Anybody noting a similar behaviour?
Forcing channel 40 speed become top but still MacBook Air is not depicted as attached by cable modem
am 15.12.2020 19:55
Hello medicol,
do the 2.4 Ghz and the 5Ghz network use the same name and password?
Best regards, Martin
am 15.12.2020 19:59
no because I want to know where I am logged in
if I am using 2.4 or 5 GHz
am 16.12.2020 18:34
@Martin59hello,
I just now set 2.4 and 5 GHz SSID equal in my CH7466CE running Firmware version 4.50.21.4
I attached PC, Mac, iPad, mobile phones.
I attached them in front of the modem so they well see 5 GHz.
Going to Router » Basic » My Network, no more than 1 device is depicted attached to 5 GHz.
If I move my mobile phone to another room, then it is depicted as attached to 2.4 GHz (it autonomously change frequency because signal at 5 GHz is weaker than 2.4 GHz, this is right behaviour) together another device that can only be camped there, at the same time another device pop up as attached to 5 GHz
Considering that devices not depicted in Router » Basic » My Network are still working using wifi means that modem has bug.
am 20.12.2020 18:16
can anybody help to solve the bug?
am 21.12.2020 13:35
Hello medicol,
we know that sometimes not all devices are displayed in the device overview, although they are connected via W-LAN.
This will be fixed with one of the next software updates. Now the question is still open, if your MacBook can connect again or not.
am 21.12.2020 16:41
@Martin59 at this moment MacBook can connect to Wifi 5 GHz
Please be aware: at 5 GHz only 1 device and no more than 1 is displayed
I keep now only one SSID
So that I wait fw update
thanks for info
regards
am 23.12.2020 19:30
anyway:
MacBook at 5 GHz sometimes I must turn off / turn on wifi otherwise stay stuck
the same for mobile phones
definitivly this Compal FW is full of bugs
am 24.12.2020 18:56
today 24.12.2020 modem restarted 2 times, I do not know the reason.
To get access then must turn off/ turn on my android mobile phone
this firmware is totally bad
am 25.12.2020 08:41
In order to have a better stable wifi connection I turned off 5 GHz.
I connect to it with my Windows 10 PC via 2.4 GHz and
then Wifi -> Channel Map
PC lost Wifi Connection
I tried 2 times and same result
