Tariff change to lower speed one
EORomb
Hello,
My current Internet contract with Vodafone is Red Internet & Phone 1000 Cable, which started on 05.08.2020.
When I selected this tariff using Check24 it was said that after 6 months I can free of charge change to lower speed one.
I would like to change the tariff to a Red Internet & Phone 250 Cable at 39.99€/month) starting from 05.02.2021. However, when I use the option "Tariff wechsel" in MeinVodafone account, the only option I can "change to" is the basically same one (Red Internet & Phone 1000 Cable).
Could some moderator here please help me to make the change?
Thank you.
Tina
Hello EORomb,
thank you for your pn.
I have ordered the switch to internet & phone 250 as of 5th of february 2021. You will receive the order confirmation separately.
Best regards
Tina
4 Antworten 4
Stephan
Hi EORomb,
do you still need our help or has your concern been resolved in the meantime?
If you still need assistance please send me a private message with the following information:
your name
your address
date of birth
your customer number
the link of this thread
Please reply here when you have sent the private message.
Regards
Stephan
Hi Stephan,
I have just sent a PM to you.
Thank you.
Tina
Hello EORomb,
Best regards
Tina
EORomb
Hello Tina,
thank you for your help.
Regards
