Do I get a QR code to return the old DSL router
Kaufburen
Hallo ,
Ich habe meinen Kontakt mit der Kundennummer xxx abgebrochen und möchte das Gerät an das Nunburg-Büro zurücksenden. Bekomme ich einen bei DHL zu produzierenden QR-Code zum Versenden? Können Sie mir bitte helfen, das Gerät zurückzugeben?
Grüße,
Kaufburen
::::Original Text:::
Hi all,
I have cancelled my contarct with customer number xxx and I would like to return the device to Nunburg office. Do I get a QR code to produce at DHL to send it? Can you please help me to return the device?
Regards,
Kaufburen
Edit: Personal details are nothing that belogs openly on the internet.
Edit: @Kaufburen moved in to the right board
Grit
Hello Kaufburen
please use the return slip that was originally in the package. If you don't have it anymore, you have to send it back at your own expense.
Regards
Grit
2 Antworten 2
MasterScorpion
DSL or Cable ?
Making sure your in the right board and get the right adress.
Grit
Hello Kaufburen
Regards
Grit
