Change of address
adityaKhanna
Hello,
I moved to new place. I transferred the interet cable connection, I just want to update my new address on portal.
I have documents ready.
Thanks,
Aditya Khanna
Edit: @adityaKhanna moved in to the right board
5 Antworten 5
Stephan
Hi adityaKhanna,
welcome to our community.
You wrote, that you transferred the cable connection already. So you've already reported your move to customer service?
Regards
Stephan
Hello,
 I have the request to change address on cable customer service portal and number is *** . Can you please tell me what docs or info you need to update my address on portal. No help required to move router and connection, just address update on portal.
Thanks,
Aditya Khanna
EDIT: @adityaKhanna personal data deleted
Stephan
Hi adityaKhanna,
if it is just a move from one address to another, we need no special documents.
But I can check on the current processing status. Please send me a private message with the following information:
your name
your address
your customer number
the link of this thread
Please reply here when you have sent the private message.
Regards
Stephan
Hello Stephan,
I have messaged you the above asked information.
Thanks,
Aditya Khanna
Stephan
Hi adityaKhanna,
we have received your relocation notification. When you connect the router in the new apartment, the move will be completed in the system and your addresses will be updated.
Regards
Stephan
