am 23.07.2018 11:31
I have two separate contracts - one for internet and phone and another for cable for some reason and when I go to change the SEPA Mandat in my online account I only see the internet/phone contract.
Can you help me change my cable contract SEPA Lastschriftmandat, please?
Thanks!
am 23.07.2018 21:06
Hello wealas,
you can also add the other contract to my Vodafone. Then you can also change the bank details. Otherwise you can change the SEPA mandate via the contact form or have it deposited.
Regards
Grit
23.07.2018 12:33 - bearbeitet 23.07.2018 12:42
In "My Vodafone" you can "connect 2 different user accounts". Login and beside your name click on the gear symbol and then choose below "connect accounts" and follow the instructions. If it works you can change your sepa mandat .
Or you go to kabel.vodafone.de and login there to change the sepa mandat.
Good luck with that.![]()
am 23.07.2018 13:04
Thanks, but the two contracts are under the same customer number so there is only one account. I can see both contracts under contract data (at kabel.vodadone.de) but when I go to change the bank details I don't get a second tab for the cable contract.
I was hoping an admin could point me to the sepa form so I can send it in or maybe they can figure out why the second contract doesn't show up under bank account settings.
am 23.07.2018 13:12
am 23.07.2018 13:27
I found that one, but I thought it can't be used anymore (https://forum.vodafone.de/t5/CallYa/SEPA-Mandat-f%C3%BCr-Komfortaufladung/m-p/1688825/highlight/true...) or is it good for cable but not CallYa?
Thanks!
am 23.07.2018 13:33
The info dok 230 can be used in general.
am 23.07.2018 14:10
Thanks, just sent it out, we'll see if it works next month 🙂
am 23.07.2018 14:12
Just give a short response if it works or if not.
am 23.07.2018 19:55
That was quick, got an email an hour ago that the request was processed.
And now, when I go to my online account, I can actually see the cable contract under bank details and I can change the SEPA account as well if it changes in the future.
It looks like the cable contract had something weird going on in the system.
Thanks for all your help!
am 23.07.2018 20:02
Good to hear.
Have a nice week. ![]()
