Cancel my Kabel contract
Sjdhdjiekfj
I recently relocated from Hamburg to Berlin, I sent all the documents requesting to cancel my contract since I’m currently subletting and the main tenant already has a connection. Nevertheless I’ve received via e ail a new contract activated at the new address and a communication that a technician will call me.
13 Antworten 13
Stephan
Hi Sjdhdjiekfj,
if the Internet line can also be made available at the new address, the contract will be transferred to the new address.
In this case, you cannot cancel the contract prematurely due to a move.
Regards
Stephan
in the apartment where I moved, the main tenant already has an internet connection in his name. How can it be possible to have the connection moved here? Are you suggesting there will be two internet connections in the same apartment? That doesn't sound correct to me.
please advice, the customer service replied to ask for a solution to the problem on the forum
Grit
Hello Sjdhdjiekfj,
is the existing connection a cable connection or any of Vodafone's at all? If so, we will check it out. If not, then it is not important and the contract will not be terminated prematurely.
Regards
Grit
Sjdhdjiekfj
Thanks for you answers:
The WiFi name is KabelBox-8328 and I remember seeing the cable, so I’m sure it’s a cable connection. I will look this evening. Can you tell me what other information do you need so that I can gather it?
the modem is a sagemcom f@st 5460 and given the ip address it's defenitely Vodafone
Grit
Hello Sjdhdjiekfj,
we are examining this. Send us your name, address, customer number and date of birth. We also need the moving date and the new address. If a cable contract already exists there, we need the name, address and customer number of the contract holder of the other contract. Send me all data in a private message and then contact me again here in the thread. Please note, if data is missing, we cannot process it.
Regards
Grit
Sjdhdjiekfj
Hello Grit,
I’ve sent you the required information.
Thomas
Hi Sjdhdjiekfj,
the contract has already been terminated. A confirmation was sent to you by mail on 01.03.2019.
Regards
Thomas
