A copy of the contract
DariaKameneva
I found out that I apparently lost my own copy of the contract for Kabel Deutschland, is it possible to request a copy to be sent to me again?
Regards,
Daria
reneromann
You might have a look at the "Mein Kabel" self-service portal - there is an item called "Meine Dokumente" (My documents) that contains all the documents that have been sent to you in the last 12 months - in case you made your contract in that time, the information should be there.
8 Antworten 8
reneromann
@reneromann , thanks, I checked there and what I can find is the document called "Auftrag" and tbh as a not so good German speaker I am not sure if this is the document I'm looking for 😄 I am expecting something called Vertrag. Do you know if there is a difference?
That should be the one that you are looking for.
That "Auftrag" can be translated as "Request for a contract" or in that case it is more likely to be understood as reply to your request for a contract.
Got it, thanks a lot!
Tina
Hello DariaKameneva,
I already have your customer data. Do you want the copy by e-mail? If so, send me your email address in a private message.
Best regards
Tina
Hi DariaKameneva,
I placed your mailaddress in your customer data. You'll get a message to verify your address.
After done so, please respond here again. Thanks.
Regards
Stephan
Thanks, it's done now.
Stephan
Hi DariaKameneva,
I'll send you another copy of your contract. Btw. the document you found in your customer portal was the right one. Smiley (zwinkernd)
Not bad for a "not so good German speaker". Smiley (fröhlich)
Regards
Stephan
