WiFi 5 GHz is not stable on Vodafone cable router
thekordy
I have a cable internet subscription from Vodafone for 2 years now. 5 GHz WiFi connection for more than one year.
As the two WiFi frequncy bands 2.4 and 5GHz are enabled on the router, I could only depend on 2.4 for stable connection, the 5GHz only works for a few days and then all 5GHz connections,
What I've tried so far to fix the issue:
  • Restarting the router
  • Changing channel frequency
  • Changing wifi SSID name
  • Resetting the router settings
  • Changing router location
  • Inspecting the wifi on different client devices (My mobile, the TV, my laptop, ..etc)
  • Moving to a new house 🙂
But nothing worked. I have no issues with the internet connection neither the 2.4 GHz wifi.
I tried to call the hotline and the whatsapp group, but could not get to anyone who speaks English. I want to change the router I think the problem could be related to the router itself.
4 Antworten 4
Wulpor
Hello ,
did you put the FB to factory default and established the connections again ? maybe a flaut in the system !?
or write to the support via email, that should be possible . describe your problems and or ask for furter assistance
also use the chanals 52-64 or 100 - 140 might help it
i hope i could helped you a little
Nur tote Fische schwimmen mit dem Strom
thekordy
@Wulpor Thanks For your reply, Could you please write me the support email address?
Wulpor
well try the usual emailadress for Vodafon or this following link...
https://forum.vodafone.de/t5/Internet-Telefon-TV-über-DSL/English-speaking-hotline/td-p/1547804
did u manage to set your box to factorydefault ( werkseinstellung in german) ?
Enrike
I have the same problem. The Wifi is not really stable. I tried with several devices and a Factory reset but still the same problem since they change my old router to the new VF. I am conected to any device and suddently it says to log in again as there is no internet conection. After 10-15 seconds the device conect again.
I also tried to change the Wifi Channel to a fix channel but it has the same problem.
Also i lost the VOWifi that i was able to use in the previous Router as at home i have no mobile network.
Anyone can help me, please.
Thank you.
