TG3442DE and Realtek WiFi
gcivardi
Hi! Last year I had problems with the new firmware, and after some complaints it was reverted to the old version.
However, I now got an external 2.4/5 Ghz WiFi USB adapter, and it's based on the RTL8812BU chipset.
Looks like I stumbled into another bug 😞 The 2.4Ghz band works, but the 5Ghz doesn't. No matter the configuration, I can't see the network at all while scanning.
Is there an update coming to fix this problem?
so far no new bug is known, is it simply because of the adapter? What did you try actually?
Regards
