Router replacement
Daveed
Hi there,
I would like to request a router replacement. The one I have "FritzBox 6490 Cable" is quite old and the wi-fi connection is not the best anymore. I am paying 5 euros per month for this router and I believe it is time to replace it after 5 years.
Let me know what information do you need.
Cheers
Daveed
Wallace
You pay a one-off fee of 29.99€ for the change and the monthly costs remain the same. You must not forget to return the old 6490 to us.
Regards
Wallace
Wallace
Hi Daveed,
You can book the FRITZ!Box 6660 in your customer portal.
Regards
Wallace
Daveed
Hi Wallace,
I found the option to book FritzBox 6660. If I do that, what will happen to the old one? Will the 5 euro subscription for the old one move to the new one? Or I will have to pay for both?
Cheers
Daveed
Wallace
Regards
Wallace
