INSTALLATION - Internet cable isn't compatible with laptop
Isonbek
Youngster
Youngster
Hi, I'm trying to install my new internet but the yellow cable is not compatible with my Apple laptop. How do I get around this?
2 Antworten 2
reneromann
You'll need to buy an adaptor at your own expenses.
The yellow cable is a regular Gigabit Ethernet cable - and if your Macbook has no built-in ethernet card, you'll need that kind of "adaptor" - most likely a USB Gigabit Ethernet card (which will likely only support speeds of up to 200...300 MBit/s, maybe even less.
RobertP
why not using wifi?
