CBN CH7466CE Issues
aflynn
Hello,
I recently recieved the CBN CH7466CE to replace the FAST 5460, and I must say I miss the FAST 5460. The CBN modem is awful, the WLAN is absolute trash, it never stays connect and I have to restart the modem at leat once a week if not more often just to get it to function as it should. Is there any firmware upgrade or anything I can do to make it work properly?
Thanks.
7 Antworten 7
Hello aflynn,
which firmware does the CBN have currently? Do you have trouble with both the 2.4GHz WiFi and the 5 GHz WiFi? Did you rename them so they don't use the same SSID?
Kind regards
Hello Claudia
The firnware verson is 4.50.20.3. The networks are have 2 different names, so that's no the issue. There are issues with both but the 5GHz is much worse.
Thanks,
Alyssa
Martin59
Hello aflynn,
do you use a repeater or do you connect the devices directly to the W-LAN of the cable router?
Best regards, Martin
Hi Martin,
I was using the WLAN from the modem with all of my devices, expect for one because it only works with the b band so I set up a secondary router inorder to use it. However I have switch almost all if not all of my devices to the other router now because I have less issues with that one.
Martin59
Hi aflynn,
Thank you for your answer.
If you like, we would be happy to exchange our cable router to see if the error is fixed.
Hi Martin,
Alright, lets give it a try.
Kind Regards,
Alyssa
Martin59
Hi aflynn,
I just ordered the router replacement.
You will receive the new device within the next 3-5 working days.
Just plug it in as usual and send us the old device back.
