Red Internet und Phone 100 DSL Speed Problem !!
moh95
Hello, Good day!
I had ordered ( Red Internet and Phone 100 DSL)  internet connection and its already start working from 12 April, 2019. The trouble i am facing is about the internet speed even at the moment downloading i am getting is about 13.8 Mbps even. What should i do on it?
Hope to hear anything soon.
Regards,
Mohsin
Seb4sti4n
Hello moh95,
please check your landline via http://www.speedcheck.vodafone.de and do not use WiFi. Thank you!
Best Regards
Sebastian
2 Antworten 2
Jens-K
Hi moh95,
just to make sure that you know: There is a difference between MB/s and Mbit/s.
With a 100 Mbit/s connection your download speed is 12,5 MB/s
In order to check your bandwidth, please do some tests here: http://www.speedcheck.vodafone.de
Please use a LAN-connection and no WIFI. No parallel downloads or streams.
You can post the results here, but please do not post the ticket numbers. Thank you.
Regards,
Jens
Seb4sti4n
Hello moh95,
Best Regards
Sebastian
