Change contract from Cable to DSL
Mines
Hello,
I've made a contract to have internet Cable at my place. However, when trying to make the appointment for the connection I was told that Cable is not available in my building. It has to be a DSL connection.
What do I have to do to change my contract from Cable to DSL? Do I need to cancel my contract?
Your help would be highly appreciated.
Thomas
Hi Mines,
the contract's out. You will get a confirmation.
Regards
Thomas
16 Antworten 16
Thomas
Hi Mines,
let's take a look. Send me your customer number, name, date of birth and address in a private message.
Then reply here again in the post.
Regards
Thomas
Mines
Hi Thomas,
My customer number: ***
Date of birth: ***
Address: ***
Thank you,
Mines
Edit: @Mines personal data removed
Thomas
Hi Mines,
connection via cable is possible. But something has to be built. We are already in contact with the property management and will implement this as soon as possible.
Regards
Thomas
Mines
Thank you so much for your reply.
I need to get internet as soon as possible in my place. I'm afraid this cable solution might take too much time.
Can I get the DSL instead, so the installation of internet can be quicker?
Best,
Mines
Thomas
Hi Mines,
the DSL connection would also have to be installed by a technician. Whether there goes faster is not sure. The use of the cable line is also always preferred. The property management will certainly not need so long to clarify this.
Regards
Thomas
Mines
What are the next steps? Should I wait from a reply from your side?
Thanks,
Mines
Thomas
Hi Mines,
as soon as there is a feedback from the property management, we will install the connection. Unfortunately, you will not receive any information automatically.
Regards
Thomas
Mines
Hi again,
I've been talking to my neighbours and the information that we have from the company that manages our building is that we they don't know when the instalation of Kabel will occur. It has been months since these negotiations have been going on.
Unfortunately I can't be in this situation of wainting for something that I don't know when it's going to happen. I kindly ask you to terminate my contract or at least tell me what should I do to cancel it. I need to work from home and I need to find a solution as soon as possible for this.
Best regards,
Mines
Thomas
Hallo Mines,
i don't have any new information either. I can offer you to cancel the contract and you order a DSL contract.
Regards
Thomas
