No obvious way to check internet usage - that's a shame
vinfer
Rookie
Rookie
I have been researching for more than an hour about how to check my internet usage. I tried çenter.vodafone.de, but it only offers me new plans, no data usage. I also tried to register at the website, it then asks my customer password that I was never provided with.
How can that be possible that in 2019 is so impossible to simple check my data balance?
That is a shame!
I looking for a solution for my pre-paid sim. Thanks.
reneromann
center.vodafone.de usually should work. But keep in mind that this only works, if you are connected using the mobile network AND NOT if using a wireless network at home!
Mav1976
For checking your balance, internet usage, free contingent (SMS/calls) you can use the app MeinVodafone.
When you use CallYa Flex then you have to use the app CallYa Flex app.
Also you can go to wap.meincallya.de
