am 28.01.2021 12:47
Hi Vodafone team,
I purchased a Call Ya phone card from one of your City Centers Store almost 7 years ago, and suddenly it stop working Yesterday,
I have all the original receipts etc. but i don't think i was given a Customer ID or Pin Number, and unfortunately the Store is closed due to Corona.
I would want a new Sim card sent to me @ my new address, so i can continue using the service. Would appreciate if someone can help me.
Thanks.
am 28.01.2021 14:14
Easiest way is to call the CallYa hotline - this can also be done from other phones.
As far as I know, the initial password back in that time would've been the PUK that was delivered together with the SIM card - you should give it a try (but please note that you might be required to speak German).
am 28.01.2021 14:28
Hi Renero,
Thanks for the tip, i try going a bit outside the city center where some Vodafone "agents" stores are still open, but they told me i need to contact Vodafone myself and figure out how to reset the password etc., not much they can do from the store.
My wife's German, but she's at work, so i figured i search around internet for some answer, and came across these forums and an older post which i guess people were having the same problem as me.
https://forum.vodafone.de/t5/CallYa/Customer-Number-and-Password/td-p/1379138
I also tried the PUK and few other numbers earlier, but nothing worked (and of course after 3 try, it locks for 24 Hrs).
See if one of the moderator answers (maybe i will try to PM them) or wait till my Wife gets home.
Thanks again for your message. Nice to see a nice community set up here.
am 29.01.2021 11:31
Hi @Sam12345,
i recommend that you call the hotline 01722290229 in this case as well. Some agents also speak English.
The forum is not always occupied by moderators.
Maybe your card was switched off because it was not used. Then this can be reactivated very easily.
You can send me your number as a PM. The answer can take a while.
Many greatings,
AnnikaP
am 29.01.2021 15:12
Hi Annika,
Thank you for your message, my Wife contacted Vodafone for me, and figured out the problem.
Thanks for all the help.
Cheers
