Low speed,frequent Internet broken connections although wifi is connected, watsapp calling forbidden
SaurabhShukla
Hello,
I have taken vodafone connection newly. Following seems to be technical problem.
1 - You promised speed of 1 GBPS, but speed is very very low - 40-50 mbps.
2 - Why watsapp calling is forbidden - Watsapp calling is disconnected again again while talking.
3 - Even after full Wifi signal, some times internet doesnt run - Why?? frequency of this type of incidents has increased.
4 - Why VPN of my company is not connecting???
5 - Why have you provided customer care mail id and number? When i mailed you, you say to create new blog in vodafone community? Do you think customer has lot of time?
Please address this issue and give me what you have promised. Saurabh
27 Antworten 27
I changed my house, but here also i face low speed and interrupted connections.
Attached is the speed , checked with ethernet cable.
Plan is of 1000 mbps,  and getting only 300-400 mbps.
Please check and correct this.
Best Regards,
Saurabh
in that case we just need your new customerdata, could you send it please via private message?
Regards
Hi Tobias,
How do i reply you privately? I see no option here.
But i guess you have all my data from previous complaints. Feel free to give me  a call or let me know how do i reply you privately.
BR, Saurabh
Moni_GK
Hello SaurabhShukla,
we are unable to make a phone call. But you are welcome to send me a PN through this.
Best regards
Moni
Hi Moni,
Sent. Please check private messages.
BR, Saurabh
thanks for the data, so the connection seems fine, i cant see any failures or something else. So, you just checking the speed via wifi? Could you try it via lan?
Regards
Tobias Hi,
Any activity on this issue? The data which was sent to you was via LAN only, not with Wifi.
You dont see any failure on your side? Do you see that i am getting 1GBPS? and no connections interruptions?
BR, Saurabh
Martin59
we checked your line and couldn't find any fault.  Die Signalwerte sehen sehr gut aus und auch das Modem zeigt keinerlei Abbrüche.
The signal values look very good and the modem does not show any interruptions.
Best regards, Martin.
