am 30.09.2022 15:11
Hi Dear Official,
I am using Homespot more than 3 months and last 3-4 days in the middle of the day I have disconnected for 4-5 times around 2 hours for each. Mostly these waves come at business hours and it jeopardizes my work.
Would you please check and fix this issue?
Kind Regards
My homespot adress : bauer straße
Physcal Mac : 1C-C1-0C-56-D5-D3
Broken times : 30.09.2022 from 8:00 to at least 10 o'clock ( i left the home for working)
29.09.2022 12:30-14:00
28.09.2022 14:00-16:00
am 01.10.2022 14:19
Hello Burak @burakguler
thanks for your request. A collague of mine (Vodafone technical cable support) should get in touch with you asap. Kind regards, Jioti
am 03.10.2022 07:50
Dear Joti,
No one reach me and problem still continues. Your service is holted and as far as I see no action taken. What should I do make you fix this problem?
Kind Regards
am 05.10.2022 10:54
Hi burakguler,
A maximum of 5 devices can be logged on to a homespot at the same time. So it is quite possible that too many devices are already connected to the homespot at peak times.
Regards
Walllace
