am 22.01.2025 11:20
am 25.01.2025 21:23
Contact Vodafone about your internet connection disruption
Dein Kontakt zu Vodafone - Vodafone Community
No support in the forums.
am 22.01.2025 18:42
Does the internet work properly via cable? The problem with WiFi is that there are tons of external influences that can affect the WiFi performance - and therefore no provider guarantees performance.
am 23.01.2025 10:55
No, the internet doesn't work even with direct LAN connection.
There is a red light over 'mobile' continuously blinking on my wifi router
am 25.01.2025 21:23
am 25.01.2025 21:26
The thread has been marked as resolved. Then I'll close the thread here.
Best regards Kurt
