Terrible internet connection from last 3 weeks. Slow speed , no internet
Mahak
Dear Community member,
From last 3 weeks I am facing terrible internet connection at Landsberg am lech 86899.
I am using the  LAN connection and time to time internet get disconnected I have already tried with restarting the device multiple times but no luck.
My Best
Mahak
15 Antworten 15
Martin59
Hello Mahak,
have you ever reset the cable router to factory settings?
Please send me the name of the contract holder, the date of birth, the customer number and the complete address via PN.
Afterwards, please leave a short feedback here.
Best regards, Martin
Mahak
Hallo @Martin59 ,
Requested information has been sent .
My best
Mahak
Mahak
Just to add, i have not done factory reset.
Martin59
Hello Mahak,
I would like to hire a technician to look at it on site. At your connection, various values no longer fit, which must be readjusted by the technician. Please send me another PN , this time with a current mobile phone number and the info, whether you can establish access to the house system.
Mahak
Hello @Martin59 Martin,
I have sent you the message
regards
Mahak
ERFD
Ex-Moderator:in
Ex-Moderator:in
Hello Mahak,
the connection is indeed very poor. The levels on the modem on all downstream frequencies are too low and cause too many errors during transmission. This causes dropouts and bandwidth problems. Is the supplied cable permanently connected between the modem and the antenna socket? If not, a technician will need to look at this.
He needs access to the house distribution system, the connections in the living room and an info if there are known diseases with Covid 19 in the household. Please also note and read this.
Best regards Fred
Mahak
Hello @ERFD
The connection cable is connected with modem and the modem is not in living room but in the children bedroom. Does this make any difference?
How these frequencies can be set ?
Regards,
Mahak
ERFD
Ex-Moderator:in
Ex-Moderator:in
Hello Mahak,
has the modem always been located where it is currently? Is there another socket in the apartment?
Best regards Fred
Mahak
Hi @ERFD
Modem was located in living room in the starting . Because there was  problem with WLAN and to use the LAN option  I have moved the modem to another room (current place) 5-6 months before
Best regards,
Ankit
