am 11.01.2024 19:16
Ich habe seit geraumer Zeit ständig Abbrüche im Wlan und weiß nicht woher bzw was diese ganzen Meldungen bedeuten.
Ich hoffe auf schnelle Hilfe.
MfG
2024-01-10 17:53:23 log.warn [88000102]: 1,2024-01-10 17:53:23 Radio=wl0; k1_SSID Device DE:5C:B6:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=4.
2024-01-11 06:11:11 log.warn [88000102]: 1,2024-01-11 06:11:11 Radio=wl1; k2_SSID Device DE:5C:B6:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=4.
2024-01-11 18:43:06 log.warn [88000102]: 1,2024-01-11 18:43:06 Radio=wl0; k1_SSID Device 50:23:6D:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=3.
2024-01-11 18:44:32 log.warn [88000107]: 3,2024-01-11 18:43:05 k1_SSID Black Address List Detected: 50:23:6d:00:00:00
2024-01-11 18:45:39 log.warn [88000101]: 3127,2024-01-10 17:42:46 k1_SSID; Device Associated. WG-MAC=50:23:6D:00:00:00;SSID="Vodafone-632C";On Channel=1;Sec-Mode=68.
2024-01-11 18:46:12 log.info [88000301]: 1,2024-01-11 18:46:12 radio=wl0: Configuration Changed. ACSD Changing Channel to 6.
2024-01-11 18:46:36 log.warn [88000101]: 4943,2024-01-11 18:46:23 k1_SSID; Device Associated. WG-MAC=DE:5C:B6:00:00:00;SSID="Vodafone-632C";On Channel=6;Sec-Mode=68.
2024-01-11 18:48:10 log.warn [88000101]: 4949,2024-01-11 18:46:39 k2_SSID; Device Associated. WG-MAC=DE:5C:B6:00:00:00;SSID="Vodafone-632C";On Channel=108;Sec-Mode=68.
2024-01-11 18:48:10 log.warn [88000102]: 7,2024-01-10 17:25:40 Radio=wl1; k2_SSID Device DE:5C:B6:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=8.
2024-01-11 18:48:20 log.warn [88000101]: 4955,2024-01-11 18:47:06 k1_SSID; Device Associated. WG-MAC=6C:3C:7C:00:00:00;SSID="Vodafone-632C";On Channel=6;Sec-Mode=68.
2024-01-11 18:48:26 log.info [88000301]: 2,2024-01-11 18:45:52 Radio=wl0 ; SSID=Vodafone-632C;k1_SSID Configuration Changed. Password Changed
2024-01-11 18:48:35 log.info [88000301]: 2,2024-01-11 18:48:34 radio=wl0: Configuration Changed. ACSD Changing Channel to 8.
2024-01-11 18:48:42 log.info [88000301]: 3,2024-01-11 18:45:52 Radio=wl1 ; SSID=Vodafone-632C;k2_SSID Configuration Changed. Password Changed
2024-01-11 18:48:42 log.warn [88000101]: 4961,2024-01-11 18:48:42 k1_SSID; Device Associated. WG-MAC=6C:3C:7C:00:00:00;SSID="Vodafone-632C";On Channel=8;Sec-Mode=68.
2024-01-11 18:48:59 log.warn [88000102]: 1,2024-01-11 18:48:59 Radio=wl0; k1_SSID Device 6C:3C:7C:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=8.
2024-01-11 18:50:07 log.info [88000301]: 12,2024-01-11 18:50:07 Radio=wl1;k2_SSID Operating Parameter Changed. ACS Setting Channel = 52.
2024-01-11 18:55:43 log.warn [88000101]: 4992,2024-01-11 18:53:45 k2_SSID; Device Associated. WG-MAC=DE:5C:B6:00:00:00;SSID="Vodafone-632C";On Channel=52;Sec-Mode=68.
2024-01-11 18:56:05 log.warn [88000101]: 4538,2024-01-11 17:31:26 k1_SSID; Device Associated. WG-MAC=BC:45:5B:00:00:00;SSID="Vodafone-632C";On Channel=1;Sec-Mode=68.
2024-01-11 18:56:05 log.warn [88000102]: 2,2024-01-11 17:33:21 Radio=wl0; k1_SSID Device BC:45:5B:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=3.
2024-01-11 19:00:32 log.info [88000301]: 12,2023-10-04 15:59:07 radio=wl0: Configuration Changed. ACSD Changing Channel to 3.
2024-01-11 19:00:35 log.warn [88000205]: 2,2024-01-10 17:20:53 k0_SSID Interface Reset ,Link is Up.
2024-01-11 19:00:59 log.info [88000301]: 10,2023-10-04 15:59:22 radio=wl1: Configuration Changed. ACSD Changing Channel to 106.
2024-01-11 19:01:02 log.info [88000301]: 1,2024-01-11 19:01:02 Radio=wl0;k1_SSID Operating Parameter Changed. ACS Setting Channel = 11.
2024-01-11 19:01:02 log.info [88000301]: 2,2024-01-11 19:01:02 Radio=wl1;k2_SSID Operating Parameter Changed. ACS Setting Channel = 108.
2024-01-11 19:01:12 log.info [88000301]: 3,2024-01-11 19:00:04 radio=wl0: Configuration Changed. ACSD Changing Channel to 9.
2024-01-11 19:01:18 log.warn [88000101]: 2,2024-01-11 19:01:18 k1_SSID; Device Associated. WG-MAC=6C:3C:7C:00:00:00;SSID="Vodafone-632C";On Channel=9;Sec-Mode=4.
2024-01-11 19:01:18 log.warn [88000101]: 3,2024-01-11 19:01:18 k1_SSID; Device Associated. WG-MAC=DE:5C:B6:00:00:00;SSID="Vodafone-632C";On Channel=9;Sec-Mode=4.
2024-01-11 19:01:19 log.info [88000301]: 23,2023-10-04 15:59:07 radio=wl0: Configuration Changed. ACSD Changing BW to 40MHz.
2024-01-11 19:01:19 log.info [88000301]: 7,2024-01-10 17:21:31 radio=wl0: Configuration Changed. ACSD Changing BW to 20MHz.
2024-01-11 19:01:19 log.info [88000301]: 5,2024-01-10 17:21:31 radio=wl0: Configuration Changed. ACSD Changing Channel to 1.
2024-01-11 19:01:22 log.warn [88000102]: 8,2024-01-10 17:29:22 Radio=wl0; k1_SSID Device DE:5C:B6:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=8.
2024-01-11 19:01:23 log.info [88000301]: 2,2024-01-10 17:22:37 Radio=wl0;k1_SSID Operating Parameter Changed. ACS Setting Channel = 1.
2024-01-11 19:01:23 log.info [88000301]: 6,2024-01-11 19:01:23 Radio=wl1;k2_SSID Operating Parameter Changed. ACS Setting Channel = 136.
2024-01-11 19:01:23 log.info [88000301]: 8,2024-01-11 19:01:23 Radio=wl1;k2_SSID Operating Parameter Changed. ACS Setting Channel = 140.
2024-01-11 19:01:23 log.info [88000301]: 19,2023-10-04 15:59:22 radio=wl1: Configuration Changed. ACSD Changing BW to 80MHz.
2024-01-11 19:01:23 log.info [88000301]: 6,2024-01-10 17:21:38 radio=wl1: Configuration Changed. ACSD Changing Channel to 58.
2024-01-11 19:02:18 log.info [88000301]: 3,2024-01-10 17:22:37 Radio=wl1;k2_SSID Operating Parameter Changed. ACS Setting Channel = 60.
2024-01-11 19:02:21 log.info [88000301]: 2,2024-01-10 17:22:40 k1_SSID Configuration Changed. BandSteering is Enabled.
2024-01-11 19:02:30 log.warn [88000102]: 9,2024-01-11 18:14:45 Radio=wl0; k1_SSID Device 6C:3C:7C:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=3.
2024-01-11 19:02:31 log.warn [88000102]: 2,2024-01-10 17:22:49 Radio=wl0; k1_SSID Device DE:5C:B6:00:00:00 disconnected from SSID=Vodafone-632C; REASON-CODE=3.
2024-01-11 19:02:33 log.warn [88000101]: 60,2024-01-10 17:21:46 k1_SSID; Device Associated. WG-MAC=DE:5C:B6:00:00:00;SSID="Vodafone-632C";On Channel=1;Sec-Mode=68.
2024-01-11 19:15:18 log.warn [88000101]: 4678,2024-01-11 17:31:44 k1_SSID; Device Associated. WG-MAC=6C:3C:7C:00:00:00;SSID="Vodafone-632C";On Channel=1;Sec-Mode=68.
2024-01-11 19:15:18 log.warn [88000101]: 1728,2024-01-10 17:24:45 k2_SSID; Device Associated. WG-MAC=DE:5C:B6:00:00:00;SSID="Vodafone-632C";On Channel=60;Sec-Mode=68.
am 11.01.2024 20:14
Schien an meiner Nintendo Switch zu liegen die irgendwelche Fehler geworfen hat oder sowas. Sind auf einmal sämtliche Fehler aus den Protokoll weg und alles wieder schick.
Ich weiß nicht ob es daran lag aber damit ist dieser Post unnötig geworden.
MfG
am 11.01.2024 19:46
Docsis Status posten, alle als Screen!
am 11.01.2024 19:52
Wie genau mache Ich das? Kenn mich da jetzt nicht so super mit aus.
am 11.01.2024 20:14
MfG
