am 14.07.2021 22:29 - zuletzt bearbeitet am 15.07.2021 06:35 von Gelöschter User
Cable connection
New Fritzbox 6660 gives only 51 -100 Mbps speed while the contract is for 1000 Mbps. Have tried everything including Factory reset of the modem.
Have tried connecting different devices. With LAN cable it gives upto 600 Mbps.
How to contact vodafone? Seems like faulty modem? Please help
Edit: @NewUser1000Mbps Beitrag nach Störungsmeldungen Kabel verschoben. Gruss Methusalem1
am 15.07.2021 09:25
Hello NewUser1000Mbps,
are you using the 2.4 or the 5 GHz WLAN?
In which state do you live?
Greetings Moni
