My internet is not working
hx
My Vodafone Kable internet service is not working. I did switch off the router for 3 min then back the power again however the problem still persists.
All the lamp is stable white and on.
details/
Vodafone router/ cga4233de
postcode/ 90443
vodafone resolved it thanks
2 Antworten 2
Jens
Hello hx,
what's wrong with the internet? Is it the connection with ethernet or can't connect with wifi?
Can you describe it a little bit more?
Regards
Jens
