Internet is not working
Shalin
Digitalisierer
Digitalisierer
Our internet stopped working since an hour before. Since I work from home, it had halted my work. We are staying in Einbecker Straße 101, 10315 Berlin.
Would be great if someone fixes this issue soon enough.
na, it costs nothing, besides of your time 😉 The new device should arrive soon.
Regards
14 Antworten 14
Shalin
Digitalisierer
Digitalisierer
BTW it started working now.
Although I experienced the downtime sporadically. Would be nice if the technical team looks into the root cause and fixes it..
Hello Shalin,
did the outage affect both WiFi and the ethernet connection? Could you reach the modem GUI? How often do the problems occur? Did you try a different coaxial cable?
Kind regards
Thanks for your reply.
It happens with wifi and since I do not have any device with ethernet port I do not use ethernet connectivity.
Yes, because wifi is on without internet connectivity.
Three to four times a day. I figured out a work around, when I restart the modem the internet starts work again. But it is a pretty painful process, because I really have to wait for few mins until the modem gets the internet access.
Yes,  the result is same!
I hope the problem is addressed and resolved soon. Thanks for reaching out to the post.
Hello Shalin,
WiFi can be disturbed by many environmental influences. Please check the hints for improving the WiFi. It would also help if you could find a device that you can connect via ethernet to check if the problems occur there, too.
Regards,
I followed the tips that was shared by you on hints for improving the WiFi
But unfortunately it did not solve the problem. Still the problem persist, do you have any other way to solve this, Should I need to raise the concern with VODAFONE in writing as a complaint or how to proceed?
I can gladly take a look at the connection 🙂 Can you send me your customer data (customer number, name, address and date of birth of the contract holder) via private message?
Then please let me know in the post when you have sent me the data.
Regards
Hello @Tobias Thanks for reaching out, I wrote a private message with the details requested. Looking forward to your reply.
hey @Shalin,
well, i can see traffic, the line for itself lookings good, whats the exact problem for now? Ive got an few timeouts here, but that shouldnt be the problem.
Regards
Hey @Tobias,
In one whole day Internet gets disconnected for no reason even for three to four times,  even after waiting for an hour internet does not work at all until we manually switch off the router and switch on again.
Since it happens 3-4times a day it affects my work from home activities badly. Hence I wanted help in this concern.
Hope you will be able to figure something out to fix this issue!
