am 21.08.2024 12:16
I have ordered a cable connection and got my Vodafone station delivered last day. But when I am trying to connect, the cable came with the router does not fit my home socket. The image of the cable and my home socket are attached.
Please help with this.
am 21.08.2024 12:45
it does fit on data outlet
press a little harder 😉
am 21.08.2024 13:50
Thanks for your reply. May i know which end goes where? and which of the four outlets in the socket i need to use?
am 21.08.2024 13:55
use the end with the angle connector on the upper right data port
am 21.08.2024 15:36
The angle connector below is going only inside the TV port since both are male
am 21.08.2024 16:01
OK sorry, then vice versa. Vodavone never send me such a cable
use the other connector and plug the angle connector into the router
am 21.08.2024 16:03
tried that as well. But the angle connector does not go into the router as well 😞
am 21.08.2024 16:07
what is written on the label on the angle connector ?
am 21.08.2024 16:12
am 21.08.2024 16:19
both sides must have a thorn in the middle
it doesn's matter which end of the cable you are using for the outlet or router
you have to press harder
