address change after cancellation
MdeVries
Hi there,
I cancelled my contract as I moved to a new flat with internet contract included, but I was wondering if I can still request an address change for the last months of the cancellation period, and if it's possible to change from cable to DSL for those months until end of cancellation period?
Kind regards,
Mirjam
Grit
Hello Mirjam,
what exactly do you want? Can you use the connection at the new address or is it available? Have you reported a move or simply given notice? In any case, a change of technology (DSL) is not possible for the remaining term. That would be a new contract with new terms and new technology, which is not possible.
Regards
Grit
MdeVries
That was my question actually - if it was possible to change to DSL for the remainder of the contract. Thanks a lot for your answer!
Kind regards,
Mirjam
Norman
Community Manager
Community Manager
Hey Mirjam,
you can switch to DSL with a new contract period of 24 month. For the remainder cable period it is not possible. Sorry.
Best regards
Norman
