No DATA port on cable socket – cannot connect Vodafone Station
Naadiya
Hello everyone,
I recently received my Vodafone Station router for a cable internet connection, but I’m unable to set it up due to my wall socket.
My current situation:
  • I have a 2-hole wall socket (TV and Radio only)
  • There is no DATA port available
  • The top section (where a DATA port usually is) seems to be covered/blocked and not usable
  • My router cable (coax) does not fit into any of the available ports
From what I understand, I might need a Multimediadose (with DATA port) to use cable internet properly.
Do I need a technician to install the correct socket for this?
Thanks in advance for your help!
Naadiya
support sent me a Multimediadose adapter after contacting them through whatsapp
5 Antworten 5
MasterScorpion
Call Costumer Service and say Selbstinstallation fehlgeschlagen that should trigger a Technician.
Okay, Thanks! 😄
Naadiya
Torsten
Since the solution is marked I'll close this thread now.
Thanks @Torsten
