faulty router
Zahra_s
Hi 🙂
I've a faulty router. wifi module is not functioning and need to restart router every few hours.
aslo is not possible to change wifi configuration from admin panel.
how could request a replacement for that?
Best
9 Antworten 9
RobertP
try a factory reset first
to do so press and hold the resetbutton with a paperclip for 20 seconds
it helps for 2 days and now, wifi diconecting and ping is too high. internet connection is really unstable with wifi
Gelöschter User
Nicht anwendbar
If the router is broken, please call the customer hotline so it can be replaced.
0800/1721212
and via lan cable the connection is stable?
yes it's, i'm using lan for work for now. also connected temporary access point to it to solve the wifi issue
unfortunately, not able to speak German. this is why asked here to find a solution
Zahra_s
I have called 2 times. they said will check soon but after 1 week nothing happens.
still using access point to connect to wifi.
what should i do. is there any email address or you are able to replace the router?
as I already wrote, use WhatsApp
this is a customer to customer forum and nobody is able to replace your router here
