Server access problem
idhamari
I am trying to access my local server from an external network but it does not work. I can access the server from the local network but not from an external network.
I already added the server to the IPv6 Host exposure over port 80.
Is there anything suggestion?
Here are some screenshots:
Screenshot from 2022-01-03 13-29-15.pngScreenshot from 2022-01-03 13-31-56.pngScreenshot from 2022-01-03 13-32-24.pngScreenshot from 2022-01-03 13-32-39.png
9 Antworten 9
RobertP
with DS Lite you cannot access your server via IPv4 from outside
so what is your suggestion?
Are you from Hessen?
What contract do you have?
Best regards Kurt
No, I am in Berlin, I have a Vodafone contract internet with cable 100MB.
Then there are only the following option:
1. Standard router in bridge mode
2. Buy your own cable router
3. Business contract with fixed IP
Best regards Kurt
Thanks Kurt,
I will try the bridge mode next week.  Any recommendation for cabel router?
Best!
If you use the bridge mode, you have to operate a router behind it. I would recommend the Fritzbox 7590 or 7490.
As a cable router I would use the Fritzbox 6591.
Best regards Kurt
for use behind bridge mode I wouldn't suggest a Fritzbox  😉
I would prefer RT-AX58U or TP-Link Archer AX55 for example
That's right if you don't want telephony to go through your own router.
That would only work with a Fritzbox.
Best regards Kurt
