am 10.10.2023 16:46
Today, I received my new router "WiFi Certified 6" or in other words "Router Station".
Following are the steps that I performed to make the router up and running
1. Connected the router to the power cable and switched on
2. Connected the data cable to the router on one side and the TV/Radio/Data(In/Out) connector to the other side
3. Switched on the router
Even after like 10 minutes the internet light is blinking red.
I also went through the instruction given the Tobio, the Network Assistant. Nothing work.
Then, I went to the admin panel and reset the router. Still nothing happened.
If someone or the Vodafone people can help in this matter?
Waiting for your reply, and, thanking in anticipation.
am 10.10.2023 17:01
am 11.10.2023 20:26
Thank you, Kurtler. I will contact them there. 🙂
