IPv6 Host exposure doesn't work
Shpuli
IPv6 Host Exposure doesn't work on Vodafone Station
I can see it's an existing issue, but it's all in german, so I better ask one more time. I need it to connect to my vpn server
Osnabrück, 250 Cabel
9 Antworten 9
Hello Shpuli,
do you get an error message? What are your settings? Do you use DSLite? Does the connection to the VPN server work when you activate the bridge mode in the customer portal? Which Vodafone Station do you use and which firmware does it have?
Kind regards,
Hello Claudia,
Firmware version:         19.3B57-1.0.41
Product name:               CGA6444VF
I expose specific ports of a NAS device in my local network under IPv6 Host Exposure tab and when trying to reach them outside I got refused to connect error. Tried to disable firewall but without success.
I am not aware what DSLite is. Didn't try bridge mode as I don't have another router.
did you configure the firewall of you NAS device correctly?
Synology NAS's firewall is disabled.
VPN and other services : Connection Test Result: Failed
pRo-Marco
Hi Shpuli,
please try uPnP with your NAS.
Kind regards
Yes I have UPnP on my Vodafone router enabled
NAS UPnP setup runs succesfully: UPnP Router Found: Technicolor CGA6444VF Firmware: 1.0
Then rules rewritting takes place.
Tried several times, doesn’t help
Hey @Shpuli,
you can bridgemode that anyway, you can just use port 1 on that device then. Maybe its worth a try.
Regards
I don’t understand. What “that” device do you mean? I have only one Vodafone router that I need to make work 🙂
Hello Shpuli,
the bridge mode turns the Vodafone router to a modem, to test the setting you can use a PC or laptop on the LAN1 port.
Kind regards,
