Moin, habe leider Probleme mit der Vodafone Station. Oft hab ich Paketverluste muss jeden Tag mein Router Neustarten was nicht sinn der sache ist.
2022-06-11 15:47:07 FwLog.crit [10000008]: 22,2022-06-11 15:25:07 UTOPIA: FW.IPv6 FORWARD drop
2022-06-11 15:48:01 FwLog.crit [10000004]: 19,2022-06-11 15:25:01 UTOPIA: Device Blocked DROP
2022-06-11 15:48:03 FwLog.crit [10000003]: 19,2022-06-11 15:25:03 UTOPIA: Service Blocked DROP
2022-06-11 15:48:05 FwLog.crit [10000007]: 20,2022-06-11 15:25:05 UTOPIA: FW.IPv6 INPUT drop
2021-09-02 02:44:53 log.info [88000301]: 1,2021-09-02 02:44:53 radio=wl0: Configuration Changed. ACSD Changing Channel to 3.
2022-06-11 15:23:28 log.info [88000301]: 2,2021-09-02 02:44:38 radio=wl0: Configuration Changed. ACSD Changing Channel to 8.
2022-06-11 15:26:52 log.info [88000301]: 1,2022-06-11 15:26:52 Radio=wl0;k1_SSID Operating Parameter Changed. ACS Setting Channel = 11.
2022-06-11 15:26:52 log.info [88000301]: 2,2022-06-11 15:26:52 Radio=wl1;k2_SSID Operating Parameter Changed. ACS Setting Channel = 104.
2022-06-11 15:26:53 log.warn [88000205]: 2,2022-06-11 15:25:12 k0_SSID Interface Reset ,Link is Up.
2022-06-11 15:26:55 log.warn [88000102]: 1,2022-06-11 15:26:55 Radio=wl0; k1_SSID Device CC:AB:2C:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=7.
2022-06-11 15:26:58 log.info [88000301]: 1,2022-06-11 15:26:58 k1_SSID Configuration Changed. BandSteering is Enabled.
2022-06-11 15:27:00 log.warn [88000107]: 2,2022-06-11 15:26:59 k1_SSID Black Address List Detected: 08:12:A5:00:00:00
2022-06-11 15:27:00 log.warn [88000102]: 1,2022-06-11 15:27:00 Radio=wl0; k1_SSID Device D4:CF:F9:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=7.
2022-06-11 15:27:02 log.warn [88000107]: 4,2022-06-11 15:26:59 k1_SSID Black Address List Detected: 7C:F6:66:00:00:00
2022-06-11 15:27:03 log.warn [88000101]: 33,2022-06-11 15:27:01 k1_SSID; Device Associated. WG-MAC=7C:F6:66:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=4.
2022-06-11 15:27:03 log.warn [88000101]: 33,2022-06-11 15:27:00 k1_SSID; Device Associated. WG-MAC=08:12:A5:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=4.
2022-06-11 15:27:03 log.warn [88000107]: 6,2022-06-11 15:26:59 k1_SSID Black Address List Detected: CC:AB:2C:00:00:00
2022-06-11 15:27:07 log.warn [88000107]: 8,2022-06-11 15:26:59 k1_SSID Black Address List Detected: 34:20:03:00:00:00
2022-06-11 15:27:10 log.info [88000301]: 3,2022-06-11 15:24:22 radio=wl1: Configuration Changed. ACSD Changing Channel to 58.
2022-06-11 15:27:11 log.warn [88000107]: 10,2022-06-11 15:26:59 k1_SSID Black Address List Detected: 44:D8:78:00:00:00
2022-06-11 15:27:12 log.warn [88000102]: 1,2022-06-11 15:27:12 Radio=wl0; k1_SSID Device 44:D8:78:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=3.
2022-06-11 15:27:12 log.warn [88000102]: 1,2022-06-11 15:27:12 Radio=wl0; k1_SSID Device CC:AB:2C:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=3.
2022-06-11 15:27:12 log.warn [88000102]: 1,2022-06-11 15:27:12 Radio=wl0; k1_SSID Device 34:20:03:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=3.
2022-06-11 15:27:13 log.warn [88000102]: 1,2022-06-11 15:27:13 Radio=wl0; k1_SSID Device 08:12:A5:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=3.
2022-06-11 15:27:16 log.warn [88000101]: 54,2022-06-11 15:27:13 k1_SSID; Device Associated. WG-MAC=44:D8:78:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:27:26 log.warn [88000102]: 2,2022-06-11 15:26:58 Radio=wl0; k1_SSID Device 7C:F6:66:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=7.
2022-06-11 15:27:27 log.warn [88000102]: 2,2022-06-11 15:26:58 Radio=wl0; k1_SSID Device 08:12:A5:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=7.
2022-06-11 15:27:30 log.info [88000301]: 13,2021-09-02 02:44:38 radio=wl0: Configuration Changed. ACSD Changing BW to 40MHz.
2022-06-11 15:27:31 log.info [88000301]: 12,2022-06-11 15:24:09 radio=wl0: Configuration Changed. ACSD Changing BW to 20MHz.
2022-06-11 15:27:31 log.info [88000301]: 11,2022-06-11 15:24:09 radio=wl0: Configuration Changed. ACSD Changing Channel to 11.
2022-06-11 15:27:33 log.warn [88000107]: 12,2022-06-11 15:26:59 k1_SSID Black Address List Detected: D4:CF:F9:00:00:00
2022-06-11 15:27:35 log.info [88000301]: 9,2021-09-02 02:44:53 radio=wl1: Configuration Changed. ACSD Changing BW to 80MHz.
2022-06-11 15:27:36 log.info [88000301]: 7,2021-09-02 02:44:53 radio=wl1: Configuration Changed. ACSD Changing Channel to 106.
2022-06-11 15:27:37 log.warn [88000102]: 1,2022-06-11 15:27:37 Radio=wl0; k1_SSID Device 34:20:03:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=7.
2022-06-11 15:27:38 log.warn [88000107]: 14,2022-06-11 15:26:59 k1_SSID Black Address List Detected: 88:F5:6E:00:00:00
2022-06-11 15:27:41 log.warn [88000102]: 2,2022-06-11 15:27:13 Radio=wl0; k1_SSID Device 7C:F6:66:00:00:00 disconnected from SSID=Vodafone-60FC; REASON-CODE=3.
2022-06-11 15:31:49 log.warn [88000107]: 16,2022-06-11 15:26:59 k1_SSID Black Address List Detected: BE:F9:E0:00:00:00
2022-06-11 15:43:47 log.warn [88000107]: 18,2022-06-11 15:26:59 k1_SSID Black Address List Detected: 38:56:3D:00:00:00
2022-06-11 15:44:45 log.warn [88000107]: 20,2022-06-11 15:26:59 k1_SSID Black Address List Detected: 00:FC:8B:00:00:00
2022-06-11 15:47:47 log.warn [88000101]: 360,2022-06-11 15:45:42 k1_SSID; Device Associated. WG-MAC=00:FC:8B:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 52,2022-06-11 15:25:18 k1_SSID; Device Associated. WG-MAC=CC:AB:2C:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 61,2022-06-11 15:25:18 k1_SSID; Device Associated. WG-MAC=7C:F6:66:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 65,2022-06-11 15:26:11 k1_SSID; Device Associated. WG-MAC=34:20:03:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 120,2022-06-11 15:27:39 k1_SSID; Device Associated. WG-MAC=88:F5:6E:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 60,2022-06-11 15:25:18 k1_SSID; Device Associated. WG-MAC=D4:CF:F9:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 75,2022-06-11 15:25:18 k1_SSID; Device Associated. WG-MAC=08:12:A5:00:00:00;SSID="Vodafone-60FC";On Channel=11;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 345,2022-06-11 15:44:40 k2_SSID; Device Associated. WG-MAC=38:56:3D:00:00:00;SSID="Vodafone-60FC";On Channel=104;Sec-Mode=68.
2022-06-11 15:47:47 log.warn [88000101]: 189,2022-06-11 15:32:16 k2_SSID; Device Associated. WG-MAC=BE:F9:E0:00:00:00;SSID="Vodafone-60FC";On Channel=104;Sec-Mode=68.
