Chat Jetzt mit TOBi chatten
Störung? Nutz unsere Hilfe bei Störung!
Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Help for Fehler 8020 error code with GigaTV Box
bengin34
Dear Moderator,
My GigaTV box is giving Fehler 8020 error code (=not connected to internet)
I also can’t navigate between channels. Menu function is not working.
I am connected to internet via LAN cable. At home, internet works well with all devices at the moment.
Even though I disconnected from electricity and re-connected several times it didn’t help.
What should I do else?
The error is already known.
https://forum.vodafone.de/t5/Eilmeldungen/Aktuelle-Einschr%C3%A4nkung-bei-GigaTV/m-p/1824980#M1208
It is being worked on.
Best regards Kurt
6 Antworten 6
Best regards Kurt
bengin34
Thanks for the info!
bengin34
Dear Kurt,
I saw in other threads that the problem is solved. I am afraid not with my device.
I still get the same error message, cannot navigate, internet comes and goes every minute (with LAN connection).
Any further advice?
Anett
Hello bengin34,
are the problems still coming?
Regards
Anett
Ich habe das gleiche Problem - gibt's eine Losung?
Moni_GK
Hallo badshadd,
eröffne bitte einen eigenen Beitrag, damit es hier für alle übersichtlich bleibt.
Moni
