am 19.09.2019 08:26
Hi. I have Kabel home wifi and it has not been working properly for 3 weeks. I cannot stream or watch any wifi based media such as Netflix or YouTube. I have conducted numberous signal tests and the average stats I have are:
18 Mbit Download; 7 Mbit Upload; 38 ms Ping.
I have followed the "tips" for imporving signal strength and these change nothing. I require a technician who speaks English to come and fix this as I am paying for a service I am not receiving from Vodafone.
am 29.09.2019 17:01
Hello.
am 30.09.2019 18:32
Hi AndyLongley,
your key points:
1. We want to know, if there is a difference between WiFi and Ethernet-connection. It could be a router problem (it appears only with WiFi) or it is a signal-problem (It also appears with Ethernet). So please prove it.
2. Please send me your name, address and customer number by PN. I'll check the signal at your place remotely.
We will not send a technician to fix the WiFi. If it is only a WiFi-Problem we will replace the modem.
And again: We do not guarantee a mimimum speed over WiFi.
Kind regards
am 01.10.2019 15:21
Hi Andy,
there are no visible issues with your connection. I think your test with Ethernet will give you some good results. If that is the fact, I will replace the modem.
Kind regards
am 01.10.2019 15:48
Hi Marco
Thank you for the update. I will conduct the test ASAP and let you know the results. Confirming you'll need the Download, Upload & Ping speeds for both Wifi and with Ethernet?
Thanks
Andy
am 01.10.2019 16:57
Hi Andy,
yes, that is, what I need to know
Thank you!
Kind regards
am 04.10.2019 16:25
Hi Andy,
I've arranged for the router exchange. The new router comes with a return note for the old one.
Regards
Wallace
