Contract cancelation
renankcb
Hello,
I will be moving to brazil next month and I would like to know how to cancel my contract.
Thanks in advance.
Grit
Hello renankcb,
i'm happy to handle the resignation. You should know in advance that it is not possible to terminate the contract immediately on the move date. There is a telecommunications law in Germany, according to which the contract is terminated 3 months after the moving date.
Send me a private message with your name, full address, customer number, date of birth, moving date and full new address. It is important that you then log back in here in the thread.
Regards
Grit
4 Antworten 4
Grit
Hello renankcb,
Regards
Grit
Tina
Hello renankcb,
thanks for your message. I took care of the resignation. You will get the confirmation in the next few days.
Best regards
Tina
Thank you for your support.
Do I have to do anythingelse? Or is it done?
Att,
Renan
Grit
Hello renankcb,
you need to send the cable router back. You will find the return modalities in the cancellation confirmation.
Regards
Grit
