forgotten equipment
basitfahad
Hello,
This morning i have sent out every equipment back to vodafone as my contract was canceled. however, i have forgot to put the small black telefone adapter in the packet! should i send the adapter to you again?
best regards
basitfahad
Edit: @basitfahad moved to the right board.
Grit
Hello basitfahad,
it's not bad if some of the accessories are missing. Don't worry about it, the real device is the important.
Regards
Grit
Grit
Hello basitfahad,
Regards
Grit
