Umzugsservice - step 2 Produktoptionen
redF0ox
Hello,
I tried to use the "Umzugsservice" because I move very soon but I'm stuck at the step 2 "
Produktoptionen", the page is loading endlessly (see attached). I tried to clean my browsing data but nothing change. What do you think might be the problem ? unfortunately I can't call because I don't speak German well enough.
Best regards
Romain
Stephan
Hi redF0ox,
thanks for your response.
I'm glad to hear that the colleagues from the shop could help you with that. I wish you all the best with your move.
If you have a new request or questions, you are welcome to get back in touch with the community.
Regards
Stephan
Tina
Hello and welcome to our community, redF0ox.
Have you used our online moving service?
Best regards
Tina
redF0ox
Hi Tina,
Yes I used it but it's ok now, I went to a Vodafone store to get some help.
Best regards
Romain
Stephan
Hi redF0ox,
Regards
Stephan
