Missing port forward option, after migration from cable 200 to cable max 1000.
radicalrj
I migrated from cable 200 to cable 1000 few months ago. Just now I realise that my new cable max router from Vodafone doesn't have port forward option.
how can I activate it?
I want to use my home VPN, but I need to forward the port to my computer that is behind the router.
After checking the internet, looks like this router doesn't have that option... I am a bit disappointed.
What can I do?
19 Antworten 19
Martin59
Hello radicalrj,
please answer the open questions from the Link , so that we can get an overview.
Best regards, Martin
contract: cable max 1000
modem: free black vodafone modem/router
error: Doesn't not have port forward option
connected: via wifi and ethernet, there is no port forward option there on the admin
operation system: mac os and windows. There is no port forward option there on the admin
start period: Since I replaced my modem from cable 200 to the new cablemax 1000
signals level: do not apply here
"modem: free black vodafone modem/router"
Wild guess - Vodafone Station ?
yes !!! it is a  Vodafone station thanks for help on that! Any idea about the port forward?
Very simple: Your contract is provided using the (contractually agreed for) DualStack-Lite operation mode. This means you get a public IPv6 network but all IPv4-traffic is sent through a carrier-grade NAT device called AFTR gateway. Therefor you share your public IPv4 with many other customers and thus are not able to set any port forwardings.
I was not aware of this contract restriction when I signed up for the upgrade.
Is there anything that I can do to solve the situation? Change the router to a fritzbox helps somehow?
Or can I request a different policy?
This "restriction" is part of private user lines since at least 2015(!)...
And the only way to get a public IPv4 for sure:
Switching to a Business tariff plan AND opting in for the additional "Feste IP-Adresse" (static IP address) option.
Of course, this makes the contract more cost intensive...
are you sure about that? because I was using port forward normally on my previous cable 200. (from 2018 until 2020 when I switched to the cable max).
Looks like the cable max is different?
The DynDns on Vodafone station also doesn't work. Can I reach my network from my ipv6 using dyndns?
Can i receive some help on this? Please?
