Internet disconnect every 10 minuets
Khaledabbas
My internet at home is disconnecting every 10 minuets.
Hello Khaledabbas,
please give us some more details. Do the disconnects happen via ethernet connection? Does the modem restart? Did you try a factory reset and replace the coaxial cable? In which federal state do you live? Did you contact the hotline?
Kind regards,
