Englische Sprachausgabe Giga Tv
empty6pack
Ich habe die Gita Tv box auf English gestellt, bekomme jedoch trotzdem eine deutsche Sprachausgabe bei TNT film und Universal Channel etc . trotz gebuchter Pakete.
Bitte um hilfe.
Danke im voraus Alex
empty6pack
Hi Wallace yes I know it was set correctly, but believe it or not whatever you have done has worked since now all dual language channels are set to English by default I just checked.
Thanks 🙂
12 Antworten 12
Colin1
Full Metal User
Full Metal User
Hallo Alex,
wenn du in Einstellungen auf Englisch gestellt hast versuch mal ein Neustart (Schalter hinten Links) ich hab ab und zu auch das Problem aber nach ein Neustart (oder auch mehrere) sind die Sender auf Englisch.
MfG
Colin1
empty6pack
Hi Colin,
Thanks mate, i've tried that several times because i read your earlier thread but no luck so far, still in German after several Reboots. I read maybe a moderator needs to help.
Cheers Alex
The question is:
Do these channels have an English sound channel. If not, you'll not be able to listen to them in English.
And I doubt that these channels are broadcasted in both, German and English [even if there is an English version available via satellite dish]...
empty6pack
Yes they have , i have tested thema all..TNT film etc...
All available in dual language, i would just like the box to preset all channels in english when switching on instead of having to manually switch over to english every time.
Hi Alex,
then wait untill a moderator will contact you here, they than can Switch the box to English.
Cheers
Colin1
empty6pack
Cheers Colin, i'll just wait 🙂
Wallace
Hi empty6pack,
Please send me your customer data (name, address, customer number) in a private message, then I switch the box to English. Let us know here when you have sent the data.
Regards
Wallace
empty6pack
Hi Wallace,
Sent ! thank you.
Wallace
Hi Alex,
The Giga Box seems to have a problem because the audio language is set correctly. Is it okay if I carry out a factory reset with the box?
Regards
Wallace
