am 24.12.2019 17:07
Hi there!
I would like to downgrade from 200 to 50. All my end devices are not designed for the 200 connection, so I cannot use the fast connection at all.
Would be very nice if someone could take care of it.
Thank you very much.
wish a nice weekend
Kind regards, Manu
am 25.12.2019 11:25
Hi YoussefHassan,
I'm sure we can help you with that.
For a closer look I need some information from you. Please send me a private message with the following information:
your name
your address
date of birth
your customer number
the link of this thread
Please reply here when you have sent the private message.
Regards
Stephan
am 05.01.2020 02:52
Cool .. I just sent the details to you in a private message .. thanks
am 06.01.2020 15:28
Hello YoussefHassan,
you have made an upgrade on 04.12.2018 also the 200 Mbit/s. The contract has a duration of 24 months and kine change guarantee included. Therefore a downgrade also 50 Mbit/s is only possible at the end of the contract period on 04.12.2020. We are not able to process this at this time. Therefore you should contact us about 3-4 months before the date. One more note: The tariff change from 200 to 50 Mbit/s is charged with a one-time fee of 19.99 Euro. Currently the price for 50 Mbit/s is 29.99 Euro per month. At the moment, we cannot say whether the tariff will still exist at the time of the changeover and under what conditions.
Regards
Grit
am 19.01.2020 15:32
Hey Grit,
Thanks for your message. I'm having internet speed of 20 Mbps on that claimed 200 Mbps. This is the reason I'd like to downgrade to be less ridicolous with this. I've been suffering from this low speed that is not even 10% of what I'm paying for more than a year. And I upgraded to 200Mbps thinking it would improve the situation.
So it's either you would be able to fix it or downgrade due to your failure to give what you claim.
Youssef
am 21.01.2020 07:34
Hi YoussefHassan,
if you have problems with your connection, we should have a look on this.
From what I can see, your router is five years old. We could replace it with a newer model. Would you be okay with that?
Reagrds
Stephan
am 22.01.2020 21:47
Yes we can try that for sure. And check the speed test, if it's still less than 50 it's not my fault to stay on the 200 Mbps, does that make sense?
Thanks,
Youssef
am 24.01.2020 12:33
Hi YoussefHassan,
okay, then we'll try that first.
You'll get the new router in the next few days. Please try it at home and let us know if the speed inreases.
Regards
Stephan
am 07.04.2020 19:08
Hey, I think currently the speed is acceptable although sometimes the internet goes down completely but that's another story.
I was also charged 100 euros in my last bill, is that the new router, should I pay for that?
am 09.04.2020 09:21
did you send the cable router back?
Best regards
Tina
