Cable contract switch to lower speeds
AmeenYousuf
Dear moderators,
i have a question regarding contract change to lower speeds and was hoping you could help me.
I have had kabel 200 since April 2018 and want to switch to a lower speed from the second year onwards.
- when should i send the connection speed reduction request? should it be 3 months before the first year ends or can this also be at the last month of the first year, so March 2019? Can i send the change request now and state the start date to be from 1st April 2019?
- what are myavailable speed options? i noticed on the website that kabel 32 has been discontinued and kabel 50 is in its stead? so available options for speed reductions are 50 mb (for 29,99 euro/month) and 100 mb (for 34,99 euro/month)? is this correct?
Kind Regards,
Ameen
5 Antworten 5
Tina
Hello AmeenYousuf,
I can deposit your change request for April now. I need the following informations from you in a private message:
full name
address
customer number
Write a short reply here afterwards.
You will find in your order confirmation which tariff you can change to.
Best regards
Tina
Hi Tina,
Thanks for getting back to me.
I have sent you the details requested in a private message.
Regards,
Ameen
Tina
Hello AmeenYousuf,
the change is possible on 3rd of april 2019. I have already deposited it. When it's time, the change will be made.
Best regards
Tina
Hi Tina,
Thank you for taking care of the issue for me.
Regards,
Ameen
Nancy
Hello AmeenYousuf,
we are happy to help. Smiley (zwinkernd)
I'll close your post and if you have a question again, just open a new thread.
Best regards
Nancy
