Nachtaktiver Router
gotit
iMin Router ist die ganze Nacht ohne Grund aktiv
Beispiel aus der Eregnisliste:
03/18/2021 02:55:57 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6fffffffffffff02b000b4352435f5052494e54455201080c1218243048606c0301082d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 02:55:58 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff40c70020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e4702ff004810b8e937e7da592a00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 02:55:58 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff0031000b4352435f5052494e54455201080c1218243048606c0301042d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 02:55:58 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff9031000b4352435f5052494e54455201080c1218243048606c0301052d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 02:55:58 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffffe031000b4352435f5052494e54455201080c1218243048606c0301062d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 02:55:58 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff3032000b4352435f5052494e54455201080c1218243048606c0301072d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 02:55:59 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff70c70020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470201004810b8e937e7da592a00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 02:55:59 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff80c70020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470202004810b8e937e7da592a00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 02:55:59 [info][WiFi][ MGMT-RX 40000000ffffffffffff0005cdb081eeffffffffffff00e2001c33353230343236663633366237376663373237333734363532303332010402040b1632080c1218243048606c0301062d1a2d0017ffff0000000000000000000000000000000000000000007f080000008001000040dd09001018020000100000]
03/18/2021 02:55:59 [info][WiFi][ MGMT-RX 40000000ffffffffffff0005cdb081eeffffffffffff60e2001c33353230343236663633366237376663373237333734363532303332010402040b1632080c1218243048606c0301072d1a2d0017ffff0000000000000000000000000000000000000000007f080000008001000040dd09001018020000100000]
03/18/2021 02:56:00 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff6038000b4352435f5052494e54455201080c1218243048606c0301052d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 02:56:00 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffffb038000b4352435f5052494e54455201080c1218243048606c0301062d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 02:56:00 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff0039000b4352435f5052494e54455201080c1218243048606c0301072d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:19 [info][WiFi][ Configuration Changed : Set Device.WiFi.AccessPoint.1.X_CISCO_COM_KickAssocDevices to true from CLIENTTOOL,old value is : false,result: Set successfully.]
03/18/2021 03:56:19 [info][WiFi][ Configuration Changed : Set Device.WiFi.AccessPoint.2.X_CISCO_COM_KickAssocDevices to true from CLIENTTOOL,old value is : false,result: Set successfully.]
03/18/2021 03:56:19 [info][WiFi][ MGMT-RX 40000000ffffffffffff60d9c7ad3131ffffffffffffd0420000010402040b1632080c1218243048606c0301062d1abc011bffff0000000000000000000000000000000000000000007f0400000804dd0b0017f20a000104000000006b070fffffffffffffdd09001018020100000000dd1e00904c33bc011bff]
03/18/2021 03:56:19 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff5083000b4352435f5052494e54455201080c1218243048606c0301052d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:19 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffffa083000b4352435f5052494e54455201080c1218243048606c0301062d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:19 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6fffffffffffff083000b4352435f5052494e54455201080c1218243048606c0301072d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:20 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff50ce0020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e47022b004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:21 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff80ce0020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e47022d004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:21 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff208a000b4352435f5052494e54455201080c1218243048606c0301052d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:21 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff708a000b4352435f5052494e54455201080c1218243048606c0301062d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:21 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffffc08a000b4352435f5052494e54455201080c1218243048606c0301072d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:21 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff90ce0020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e47022e004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:22 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffffe0ce0020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e47022f004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:22 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24ffffffffffffff0ce0020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470230004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:22 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff6090000b4352435f5052494e54455201080c1218243048606c0301042d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:22 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6fffffffffffff090000b4352435f5052494e54455201080c1218243048606c0301052d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:23 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff10cf0020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470231004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:23 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff4091000b4352435f5052494e54455201080c1218243048606c0301062d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:23 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff9091000b4352435f5052494e54455201080c1218243048606c0301072d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:53 [info][WiFi][ Configuration Changed : Set Device.WiFi.AccessPoint.1.X_CISCO_COM_KickAssocDevices to true from CLIENTTOOL,old value is : false,result: Set successfully.]
03/18/2021 03:56:53 [info][WiFi][ Configuration Changed : Set Device.WiFi.AccessPoint.2.X_CISCO_COM_KickAssocDevices to true from CLIENTTOOL,old value is : false,result: Set successfully.]
03/18/2021 03:56:53 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffffb0d80020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e47026e004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:53 [info][WiFi][ MGMT-RX 40000000ffffffffffff9c417c651138ffffffffffff701a000131010882848b961224486c32040c1830602d1aee1117ffff000001000000000000000000000000000000000000]
03/18/2021 03:56:53 [info][WiFi][ MGMT-RX 40000000ffffffffffff9c417c651138ffffffffffff801a000131010882848b961224486c32040c1830602d1aee1117ffff000001000000000000000000000000000000000000]
03/18/2021 03:56:54 [info][WiFi][ MGMT-RX 40000000ffffffffffff9c417c651138ffffffffffffa01a000131010882848b961224486c32040c1830602d1aee1117ffff000001000000000000000000000000000000000000]
03/18/2021 03:56:54 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff900b000b4352435f5052494e54455201080c1218243048606c0301052d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:54 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffffe00b000b4352435f5052494e54455201080c1218243048606c0301062d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:54 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff10d90020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470270004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:54 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffffc00c000b4352435f5052494e54455201080c1218243048606c0301082d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:55 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffff30d90020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470271004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:55 [info][WiFi][ MGMT-RX 40000000ffffffffffff9c417c651138ffffffffffff501b000131010882848b961224486c32040c1830602d1aee1117ffff000001000000000000000000000000000000000000]
03/18/2021 03:56:55 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff6012000b4352435f5052494e54455201080c1218243048606c0301052d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:56 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffffb012000b4352435f5052494e54455201080c1218243048606c0301062d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:56 [info][WiFi][ MGMT-RX 40000000ffffffffffff9c417c651138ffffffffffff601b000131010882848b961224486c32040c1830602d1aee1117ffff000001000000000000000000000000000000000000]
03/18/2021 03:56:56 [info][WiFi][ MGMT-RX 40000000ffffffffffff84ba3b03f4f6ffffffffffff9013000b4352435f5052494e54455201080c1218243048606c0301082d1a3c0000ff00000000000000000000000000000000000000000000]
03/18/2021 03:56:56 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffffa0d90020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470274004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
03/18/2021 03:56:57 [info][WiFi][ MGMT-RX 40000000ffffffffffff000e58a0e24fffffffffffffd0d90020536f6e6f735f46355871307248587673684b34556d4e51717732635358726e4e470275004810b8e937e7da592b00b8e9378847732e00490203034a02100b4e04010000004b0410000000dd21000e580806000e58a0e24e0f0210050901010a0d]
2 Antworten 2
Gelöschter User
Nicht anwendbar
Um welchen Router handelt es sich denn?
Leider kann ich mit den Zahlen auch nichts anfangen.
Da es sich aber offensichtlich um Wifi handelt, kann es sein, dass er einfach nach anderen Kanälen sucht (bei Autokanal).
ervau
Host-Legende
Host-Legende
da hilft nur Störungsmeldung und Ticket aufmachen.
Vielleicht hast Du mehr Glück als ich!
https://forum.vodafone.de/t5/Internet-Ger%C3%A4te/Arris-VF-Station-Was-passiert-hier/td-p/2555186
S. "eventlog" als Anlage bei meinem ersten Post!
Gruß und viel Erfolg
ervau
