DSL Steinenbronn
Poorasadion
Hallo!
I have a DSL contract from Vodafone and live in Steinenbronn (71144 Deutschland). My internet has not worked from 29.07.2019 (the DSL light on my modem is blinking).
Yesterday I reset my router and after enter my mic, I got this error:
Leider konnte die Einrichtung nicht erfolgreich durchgeführt werden. Grund:
Zeitüberschreitung (Timeout) während des Einrichtungsvorganges
Do you have any idea to solve this issue?
Jens-K
Hi Poorasadion,
here you can check if there is a known outage in your area: http://www.vod.af/Netz-Experte
n
If you are not able to set up your modem with the MIC after a reset, there might be an issue on the line.
You can send me a private message I will check it then. I need your name, customer number and mobile phone number.
Regards,
Jens
