21.06.2018 11:05 - bearbeitet 21.06.2018 11:09
Hi all and thanks for bearing with me for speaking english and not german. (I really tried!)
Two years ago I had a CallYa Smartphone special contract with you.
I left Germany without even thinking about it, removed the sim and replaced it with my brand new dutch one.
Is this fine or should I have canceled the contract? I don't recall having an automatic debit on it so assume once the credit is down there is nothing to worry about but would like to have it confirmed as I would hate to owe anything :S
Would it be possible for you to check the account?
Thanks!
21.06.2018 11:28 - bearbeitet 21.06.2018 11:31
Hi @mokolamou,
the big advantage over long term contracts is that CallYa is a prepaid "contract".
After 3 month without using the SIM-card, VF send you an SMS about cancellation and deactivation the SIM-card after further 30 days.
If you didn't use any services (phone, mobile data, SMS etc.) within 3 month I guess your SIM-card is already deactivated. If you should have any credit on your SIM-card then you should do a request to payout the amount to your bank account.
To check your account you have to wait to a moderator who is able to get a view to your internal account data. Please be patient because the moderators are not here 24/7. 🙂
am 21.06.2018 11:54
Thanks a lot @Mav1976!
Meaning even if I had the CallYa smartphone special plan (renewable), it just cancels itself if I don't use it?
Is it possible to have a negative balance and in this case what happens?
Sorry for all the question, just don't want any loose end in Germany 😛
am 21.06.2018 12:23
@mokolamou@ schrieb:(...)
Even so. 🙂
It's possible having a negative balance but not in this tariff. If you don't have enough balance than the tariff wouldn't renew itself.
But to play safe you should wait of a moderator I mentioned above. 🙂
am 22.06.2018 14:25
Just send me your phone number via pn and I'll take a look at it.
Many Thanks
bommel1959
